There are several things you can do to optimize the throughput performance of your Ethernet adapter to ensure maximum performance. These settings and recommendations are not required to operate your FLEX-8000/6000 Signature Series SDR, but may help.
Below is a collection of suggestions for optimizing your network adapter's throughput performance.
1. Update Your Network Drivers
Updated network adapter drivers are the single most effective way to ensure maximum performance. Check to see if your computer manufacturer has updated network drivers for your PC. You can also update network drivers by identifying the adapter manufacturer and model number, downloading the most current driver for your adapter, and installing it as per the manufacturer's instructions. A detailed description of how to do this is beyond the scope of this HelpDesk article and is not an activity that our technical support team supports.
2. Do Not Allow Windows to Power Off the Network Adapter
Windows will power down hardware devices to save power. Powering down the Ethernet adapter can result in the connection between the FLEX-8000/6000 and the SmartSDR for Windows client connection shut down. There is a device-level power management setting that will prevent this from happening.
- Open Device Manager by clicking the Start button, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.
- Now expand Network Adapters, right-click on the Ethernet device, and click Properties.
- In the window that appears, click Power Management and uncheck the option Allow the computer to turn off this device to save power.
3. Green Ethernet or Energy Efficient Ethernet (EEE)
EEE, also referred to as "Green Ethernet," is a set of enhancements to the twisted-pair and backplane Ethernet family of computer networking standards that allows for less power consumption during periods of low data activity. The intention was to reduce power consumption by 50% or more while retaining full compatibility with existing equipment. The Institute of Electrical and Electronics Engineers (IEEE), through the IEEE 802.3az task force, developed the standard. The IEEE ratified the final standard in September 2010.
Consumer Ethernet switches that support EEE will automatically adjust their respective power-saving settings so they match, but some Ethernet switches do not perform this mutual adjustment properly, resulting in poor throughput performance and dropped packets.
If your Ethernet switch and Ethernet adapter support EEE, turning it off on both the PC NIC and the Ethernet switch has been shown to eliminate data errors and occasional device disconnects in some cases.
In Windows, the EEE setting is associated with the network adapter hardware
- Open Windows Device Manager.
- Double-click Network adapters.
- Right-click the network adapter you want, and then click Properties.
- On the Advanced tab, look for energy-saving options and make the appropriate changes you want.
To change Green Ethernet settings on an Ethernet switch, refer to the Ethernet switch-specific power-saving options to make the appropriate changes.
4. Ethernet Adapter Performance Settings
Several settings are available for your PC's network adapter that can improve throughput performance. These settings are associated with the network adapter hardware
Below is a description of these options and what they do.
Maximize all adapter buffers and descriptors - Set these values as high as possible for maximum performance. On PCs with limited physical memory, this may have a negative impact as send buffers consume system memory. On most systems, however, the maximum setting can be applied without significantly reducing available memory.
Receive Buffers: The buffer size of system memory used by the adapter for received packets, which can be set to help improve the performance of outgoing network traffic, but it consumes system memory. Set to 256 for maximum data transfer.
Transmit Buffers: The buffer size of system memory used by the adapter for sending packets, which can be set to help improve the performance of outgoing network traffic, but it consumes system memory. Set to 256 for maximum data transfer.
Receive Descriptors: Sets the number of Receive Descriptors that are allocated in the host memory and used to store the received packets. This can be increased if the performance of received traffic is lacking.
Transmit Descriptors: Sets the number of Transmit Descriptors that enable the adapter to track transmit packets in the system memory. This can be increased if the performance of transmission traffic is lacking.
Receive Side Scaling (RSS): Sets the number of RSS queues that enable the efficient distribution of network receive processing across multiple CPUs in multiprocessor systems. Set the queue value to four (4)
Settings and Parameters to Disable
Turn all "offload" options OFF - In almost all cases, performance is improved only marginally when enabling network interface offload features on a PC. Offloading tasks from the CPU to the network adapter can help lower CPU usage on the PC at the expense of adapter throughput performance.
Disable Interrupt Moderation / Set Interrupt Moderation Rate to OFF - This feature groups packets together and sends them as a batch. It can be responsible for the sluggish tuning of the radio.
Disable Flow Control - It sounds counterintuitive to disable flow control, but the TCP protocol has a flow control mechanism, and if an occasional UDP packet gets dropped, it has no appreciable impact on the performance of the radio.
If your network adapter has the following adapter settings, set them as follows:
- Disable Adaptive Inter-Frame Spacing
- Disable Large Send Offload (LSO) / Large Receive Offload (LRO)
- Set Enable PME to DISABLED
- Disable Packet Priority & VLAN Tagging
- Disable Jumbo Packet
