SmartLink is a feature introduced with SmartSDR version 2 that allows you to operate your radio remotely via an internet connection. However, to function properly, your network and radio must be configured properly.
Note: These instructions assume that you are using SmartSDR for Windows. You can find more information about SmartLink in Section 9 of the SmartSDR Software User Guide:
https://www.flexradio.com/documentation/smartsdr-software-user-guide-pdf/
If you use SmartSDR for MacOS, please refer to the SmartSDR for Mac Online Manual for equivalent instructions.
PREREQUISITES:
To operate your radio remotely via SmartLink, you must have the following conditions in place:
- Your Radio must be licensed for Version 2, 3, or 4 (the Version 1 "Feature License" does not include SmartLink, even if you have Version 4 "BASIC" installed)
- Your radio must be connected to the Internet.
- Your network must be configured properly and allow access to the radio
- You must have a valid SmartLink Account.
- You must register the radio to the SmartLink Account.
- You must configure the proper Port Forwarding for the radio.
- You must properly log your remote "Client" (PC, Laptop, Maestro, Mac, IOS Device) into the same SmartLink account as the radio.
- Your computer's clock must be accurate
IMPORTANT: Be Certain That Your Computer's Clock is Accurate:
IMPORTANT: Before attempting to create a SmartLink account or register a radio to the SmartLink Authentication Server: be certain that your computer's system clock is accurate. If it is significantly out of sync, your computer may not be able to communicate with the SmartLink Server.
You have two options to accomplish this.
A) Use the Windows Settings Procedure:
Syncing Your Clock on Windows 11
- Open Settings: Click the Start button and select Settings, or press Windows + I on your keyboard.
- Navigate to Time & Language: In the Settings window, click on Time & Language.
- Select Date & Time: Under the Time & Language section, choose Date & Time.
- Enable Automatic Time Sync: Find the switch labeled Set time automatically and toggle it on. This allows Windows to automatically sync your time with internet time servers.
- Set Time Zone Automatically: If you travel frequently, you can also enable Set time zone automatically to adjust your clock based on your location.
- Manual Sync: If you want to sync immediately, scroll down to the Additional settings section and click on Sync now. You should see a confirmation message indicating that the synchronization was successful.
B) Or you can use one of several automated "time-sync" programs to keep your computer clock up to date:
- Dimension 4: Software Download – Dimension4
- Meinberg NTP: Meinberg Software Download
- Time sync tool https://www.timesynctool.com/
Test the Radio-Side Network:
Verify Internet Access
Run this procedure on a computer on the same network as the radio to retrieve your radio information and confirm if the radio has access to the internet.
Retrieving the Radio Information from a FLEX-6000 – FlexRadio
The information returned will include these lines of information, among others:
Max License: Must be V2, V3, or V4 to operate SmartLink. (V1 Licenses do NOT have SmartLink Access)
Radio IP: This is the IP Address of your radio. You will use it later in the configuration steps.
Radio Internet: Available or NONE. If it doesn't say "Available," check your radio's network connection.
Radio Firmware: You should be running the latest version of SmartSDR based on the license version installed on your radio.
Verify NAT Configuration
Certain Internet Service Providers (ISPs) utilize a network infrastructure that is not compatible with SmartLink remote operation. We need to test your network configuration to see if it is compatible with SmartLink. Or if you are using multiple routers in your own network, this too can lead to an incompatible network configuration.
To check for Multiple-NAT or CG-NAT issues, run the procedures outlined in the HelpDesk article:
How to Determine if Your Network is Configured for Multi-Level NATing and GC-NAT – FlexRadio
If your TraceRoute test reveals more than one of these "Private IP Addresses" in the list, this indicates your network has either a MULTI-NAT issue or a CG-NAT issue. In this case, you must correct the MULTI-NAT issue before proceeding, because your network configuration is not compatible with SmartLink.
To overcome the Multi-NAT Issue, you will need to do one of these two things:
a) You will need to configure the first router to operate in "Bridge Mode" and then let the second router or mesh unit do all of the WIFI, DHCP, Routing, Port Forwarding, etc.
or
b) You will need to set the second router or Mesh Unit to operate in "Access Point Mode" and let the first router do all the work of DHCP, Firewall, Port Forwarding, etc.
Overcoming CG-NAT issues:
If your ISP (Internet Service Provider) uses CG-NAT Protocol, your Internet Service is not compatible with SmartLink.
SmartLink requires that you be provided a "Routable, PUBLIC IP Address" to your station that does not use CG-NAT Protocol:
You will need to negotiate with your ISP for a compatible internet connection:
* Some ISPs will do this for free.
* Others will do it for a small additional monthly fee.
* Others will do it only for a LARGE monthly fee or a "Commercial" account.
* Still others WILL NOT, or CANNOT do it at all.
Once you have confirmed that the radio's Local Area Network is compatible with SmartLink, you are ready to configure SmartLink on the radio and your local router.
Create a SmartLink Account:
If you have not already done so, use the procedure outlined in this HelpDesk article to create and manage your SmartLink Account:
Managing Your SmartLink Account and Password – FlexRadio
Log Into Your SmartLink Account
1. Navigate to your "Radio Chooser" Screen. Then:
2. Click on the "Log In" Tab.
3. Enter the email address you used to create the intended SmartLink account. Hit the "TAB" Key.
4. Enter the Password you used when you created the SmartLink Account.
5. Hit the "Show/Hide" (eyeball) button to see the Password to check for accuracy.
(Many Log-in problems are caused by typos or Capitalization errors.)
6. Click the "Log In" button to log in to your existing SmartLink Account.
Register your Radio with the SmartLink Server
- Log in to |your cmputer with your existing SmartLink Account. (see above)
Open SmartSDR, and from the SmartSDR "Radio Chooser" screen, select "SmartLink Setup"
3. Hit the "Register" Button in SmartLink Setup.
4. When the dialog box asks, click the PTT on your mic or hit the CW Key to confirm that you have physical control over your radio. (This is a security feature to prevent someone from hijacking your radio.)
NOTE: The PTT or CW Key MUST be connected to the radio RCA PTT or KEY Jack. You cannot use a software PTT, MOX, or Maestro PTT or CW Key for this step.________________________________________________________________________________________________________________
NOTE: SmartSDR v3.9.18 and some later versions have a Software Defect that does not properly instruct you to hit the PTT/CW Key. In this case, just click "Register / UnRegister" and wait about 8 seconds. Then hit the PTT/CW Key.
If this process is successful, the radio will play a chime sound, and a green check mark will appear with the message: "Registered for SmartLink! Your Radio has been registered!"
After confirming that the Radio is REGISTERED with the SmartLink Authentication Server:
Configure your Router and SmartLink Port Forwarding Settings:
(There are two options -- AUTOMATIC or MANUAL)
Option 1:
Configure the Radio and Network for SmartLink AUTOMATIC Access:
Configure your Router For UPnP
Most routers have a feature called UPnP -- Universal Plug and Play -- which automatically creates port forwarding between your router and the radio to allow the radio to be accessed from outside your local network. This is the fastest and easiest option to get SmartLink working.
Some settings on your router may be necessary to enable SmartLink
(Instructions for how to do this are usually available by consulting your router's User Guide, or searching the Internet.)
The UPnP (Universal Plug and Play) function must be enabled in your router's configuration for the AUTOMATIC setting in SmartLink Setup to work.
- UPnP is enabled by default on some routers.
- Other routers have UPnP disabled by default, and it must be enabled in the router's configuration.
- Some other routers (ATT, for example) have UPnP permanently disabled. You may need to check your router's configuration documents.
NOTE: If UPnP is Not Available or is Not Enabled on Your Router. Configure MANUAL Port Forwarding for the Radio and Router (See the Section Below for MANUAL configuration)
(NOTE: The computer must be connected to the same network as the radio for this procedure.)
Configure your Radio for SmartLink Operation
- Open the SmartLink Setup tab/
- Click on the "Network Settings" down arrow. Select AUTOMATIC, and hit SAVE.
- Hit the TEST Button. If everything goes well, the small indicator circle should turn GREEN.
4. Hover your mouse over the indicator, and a pop-up will appear telling you the SmartLink connectivity test results. The "UPnP Ports" should show PASS.
There are three categories in the test:
* "UPnP Ports,"
* "Forwarded Ports," and
* "Hole Punch."
Only one of these three groups needs to show PASS. But the TCP and UDP Ports in a specific group BOTH must show "PASS." If both "UPnP Ports" and "Forwarded Ports" show PASS, this is OK.
If everything looks good, then log your other "Client Device" into your SmartLink Account and try to connect to your radio via SmartLink.
NOTE: To connect to the radio via Smartlink, your "Remote Client" MUST be connected to a DIFFERENT network than the Radio's home network. You cannot "test connect" SmartLink from the same network as the radio.
Option 2:
Setting Up SmartLink Using MANUAL Port Forwarding
Some ISPs or router manufacturers have permanently disabled UPnP for security reasons.
If UPnP is not available, is not enabled on your router, or you do not wish to enable UPnP, you will need to configure MANUAL port forwarding rules in your router configuration and in your radio's SmartLink Setup.
Initially, to configure and test MANUAL Port Forwarding, open your router settings and turn UPnP OFF. This will prevent port conflicts with UPnP. (You can turn UPnP back on after you get SmartLink working properly)
- Open SmartLink Setup as in the steps above.
- "Register" the Radio as in the steps above.
- Select the "Network Settings" Pull-down menu.
- Select the MANUAL button.
- Enter numbers for "External" ports into the TCP and UDP Port Boxes.
(This example uses External Ports TCP 21100 and UDP 22100 to avoid possible conflicts with UPnP-assigned ports.) - Hit the "TAB" key to set the numbers. Then Hit SAVE.
(Using "External" Port numbers such as these will prevent UPnP from configuring the same ports and will avoid a possible port conflict. - Just be sure that no other device, or other FlexRadio, is using the same ports.)
Now Configure Your Router's Port Forwarding Settings:
Create a RESERVED IP Address for your radio:
IMPORTANT: If you are using MANUAL Port Forwarding, it is very important that you edit your Router's DHCP Table to assign a "RESERVED IP Address" to your radio so that it will always receive the same IP Address every time it powers up on the network. (This is also called "Local Static" or "Manual" IP Addresses on some brands of routers.) Please consult your router's user guide for instructions for assigning RESERVED/Local Status IP Addresses.
If you do not do this, eventually your router's DHCP Server will assign a different IP Address to your radio, and this will "break" your Manual Port Forwarding rules. (The data will be sent to the OLD IP Address that the radio is no longer assigned.)
Create TWO Port Forwarding Rules for your radio:
Open your router's Port Forwarding Configuration tab
Create TWO separate Port Forwarding Rules for your radio.
(Instructions for configuring Port Forwarding on your router are available online.)
* RULE 1: Forward TCP Port 21100 (External) to Port 4994 (Internal) to your Radio's IP Address.
(Shown in the Network Settings, indicated by the Yellow Arrow above)
* RULE 2: Forward UDP Port 22100 (External) to Port 4993 (Internal) to your Radio's IP Address.
(Shown in the Network Settings, indicated by the Yellow Arrow, above)
NOTE: The "Protocol" used in each of these rules MUST be either TCP or UDP.
You cannot use the setting for "BOTH" or "TCP/UDP" offered on some routers.
Hit APPLY or OK to close the router's configuration page.
NOTE: If you have more than one FlexRadio on the same Local Area Network, you must configure TWO DIFFERENT pairs of Port Forwarding rules for the other radio, using different pairs of "External" ports.
(See below)
Return to the SmartLink Setup MANUAL screen and hit the TEST button.
- After hitting the TEST Button, the Indicator should turn GREEN after a minute.
- Hovering over the indicator should reveal "Forwarded Ports: PASS" for both the TCP port and the UDP Port.
- If everything looks good, then log your other "Client Device" into your SmartLink Account and try to connect to your radio via SmartLink.
(NOTE: Your "Remote Client" MUST be connected to a DIFFERENT network than the Radio's home network. You cannot connect to your radio or test SmartLink from the same network as the radio.
This should finish your SmartLink Setup.
If You Need to Configure A Second Radio on the SAME Network: (Two options work):
A) Use UPnP / AUTOMATIC Port Forwarding on EACH RADIO: (Recommended)
The easiest and most trouble-free method for configuring TWO or more radios on the same network is to enable UPnP on the router and configure ALL of the radios to operate in "AUTOMATIC" Mode, as described above. The radio and router will then negotiate the port forwarding rules automatically for all of the radios.
or:
B) Use MANUAL Port Forwarding on EACH RADIO:
If this is not possible or not desired. Then you must set up Multiple Pairs of port forwarding rules- one pair for EACH RADIO.
Create one pair of Port Forwarding Rules for the FIRST Radio as directed in the MANUAL Section, above:
Be certain that this is working properly before adding the second radio.
Then create TWO NEW DIFFERENT separate Port Forwarding Rules for your second radio.
* RULE 1: Forward TCP Port 21200 (External) to Port 4994 (Internal) to your Radio 2's IP Address.
* RULE 2: Forward UDP Port 22200 (External) to Port 4993 (Internal) to your Radio 2's IP Address.
Configure the SmartLink Setup "External" Ports for your SECOND Radio
Open the SmartLink Setup > Network Settings > MANUAL tab.
Use the same TCP 21200 and UDP 22200 that you used for the router's second set of Port Forwarding rules.
Enjoy your remote operations!
If you still have problems getting SmartLink to run properly, please open a HelpDesk Ticket.
