This guide shows you how to set up a FlexRadio FLEX-8000 or FLEX-6000 radio working together with a Power Genius XL (PGXL) amplifier, a Tuner Genius XL (TGXL) tuner, and an Antenna Genius (AG) antenna switch.
It applies to an all-Flex station only, meaning every device in the chain is a FlexRadio or 4O3A Genius product. If your station includes another brand of radio, amplifier, or tuner, the settings differ, and this guide does not cover them.
The four devices depend on each other, so we build the station one device at a time: connect it, configure it, and test it before adding the next. If something doesn’t work, you will know exactly which device and which step to look at, and you will save time overall.
Before you begin
Install the latest software and firmware for every device before you start, and read each release’s notes first. Reading release notes before any install is a best practice, and newer versions may change steps in this guide.
What to install
| Device | What to install | Where to get it |
| FLEX-8000 / FLEX-6000 | Latest SmartSDR for Windows (the radio updates with it) | FlexRadio website, SmartSDR Newest Releases page |
| Power Genius XL (PGXL) | Latest PGXL Utility and firmware | 4O3A Genius product software and firmware page |
| Tuner Genius XL (TGXL) | Latest TGXL Utility and firmware | 4O3A Genius product software and firmware page |
| Antenna Genius (AG) | Latest AG Utility and firmware | 4O3A Genius product software and firmware page |
The Genius device utilities run on Windows. Use the Utility that ships with a firmware release, and don’t mix versions from different releases.
What you will need
- A Windows PC running SmartSDR and the Genius utilities (a Maestro can control the radio, but you still need the PC for the utilities)
- A metal-cased 5-port or 8-port Ethernet switch, and an Ethernet cable for each device
- Coax jumpers for the radio-to-amplifier, amplifier-to-tuner, and tuner-to-switch connections
- A high-power dummy load, which every high-power station should have for testing
User guides worth downloading
- SmartSDR for Windows User Guide (current version)
- Power Genius XL User Guide
- Tuner Genius XL User Guide
- Antenna Genius User Manual
How the equipment communicates
Two streams of control data keep the four devices in step, and both are set up during the steps below.
- Radio to PGXL, TGXL, and Antenna Genius (over Ethernet). The FLEX radio sends the band, frequency, mode, and TX/RX antenna (A or B) to all three devices.
- TGXL to Antenna Genius. These two share tuning memory and antenna port selection (ports 1 to 8) through the link you create under Device Settings > Genius Integration > Antenna Genius in the TGXL Utility.
Separately, the RF signal travels over coax in one direction: radio, then PGXL, then TGXL, then Antenna Genius, then your antennas.
Power-up sequence
Power on the station in this order every time, and let each device finish booting before you start the next. The devices must establish communication with each other in this sequence.
- FlexRadio. Wait until it is fully booted and the power button LED is solid green.
- PGXL. Wait until it is fully booted.
- TGXL. Wait until it is fully booted.
- Antenna Genius. Wait until it is fully booted.
- Software. Start SmartSDR, then the PGXL, TGXL, and Antenna Genius Utilities in that same order, waiting for each program to finish loading before you open the next.
Note: If you power on the PGXL too soon after the radio, or switch it off and back on too quickly, it may not connect to the radio. Turn the PGXL off, wait 10 to 15 seconds, and turn it back on.
Step 1: Connect your equipment to your network
Put the radio, PGXL, TGXL, Antenna Genius, and your computer (or Maestro) on one Ethernet switch, and give each device a reserved IP address.
- Add a switch. Use an inexpensive, metal-cased 5-port or 8-port Ethernet switch. Connect all five devices to it, then connect the switch to your router with one cable. This keeps traffic between your devices fast and reliable, even if the router is offline or overloaded.
- Reserve an IP address for each device. In your router’s DHCP server settings, assign every device a reserved IP address so it receives the same address each time it powers up. Without reservations, a device that has been off for a long time may get a new address, which breaks port forwarding and any device-to-device links that depend on IP addresses.
- Add RFI protection (optional, recommended for high-power stations). Wrap several turns of the switch’s power cable through a MIX-31 snap-on ferrite. Pass several loops of your Ethernet cables, or at least the long run to your router, through an FT-240-31 toroid.
Step 2: Set the radio’s TX Delay
Set the TX Delay to 40 ms so the radio waits for your amplifier and tuner to be ready before it sends RF.
- Start SmartSDR for Windows and connect to your radio.
- Go to Settings > Radio Setup > TX.
- Set TX Delay to 40.
The delay holds off RF for a moment after PTT is engaged. This prevents “hot-switching,” which means sending RF through the amplifier before the other equipment is in a ready state.
Note: If you operate CW, the CW Delay must be greater than the TX Delay. Otherwise, the first CW elements can be cut off.
Step 3: Connect the PGXL
Connect the radio’s ANT1 to the amplifier’s DRIVE A, connect the amplifier’s OUTPUT A to your antenna, then add network and power.
Caution: It is easy to cross the DRIVE and OUTPUT connectors, and the A and B sides. Visually check every cable connection. Don’t rely on memory while reaching around the back of the equipment.
| From | To | Needed when |
| Radio ANT1 | PGXL DRIVE A | Always |
| PGXL OUTPUT A | Your antenna | Always |
| Radio ANT2 | PGXL DRIVE B | Using a second antenna (Side B) |
| PGXL OUTPUT B | Your second antenna | Using a second antenna (Side B) |
Then finish the physical setup:
- Connect the PGXL to your Ethernet switch.
- Connect the power cable to the PGXL.
- Turn on the PGXL with the rocker switch on the back panel.
No other cables are needed between a FLEX radio and the PGXL. PTT and band data travel over your network.
Step 4: Configure and test the PGXL
Link the amplifier to your radio in the PGXL Utility, set its band data source, then confirm it amplifies correctly into a dummy load before you connect an antenna.
Open the device settings
- Open the PGXL Utility and select the Local Devices tab.
- Select your amplifier and click Connect.
- If the utility offers an Update (a new PGXL release), choose it and let it finish.
- Click the gear icon and select Device Settings.
Configure each tab
Network tab
- Name: give your amplifier a more personal name if you like.
- Select DHCP so the amplifier requests an IP address from your router when it boots.
- Nothing else is needed on this tab for local operation.
CAT/CI-V tab
- Make no changes. This tab is not used in an all-Flex station.
FlexRadio tab
- Check the Port A box.
- In the Serial Number drop-down, select your radio’s serial number. This links the amplifier to the radio for band, frequency, and mode information.
- In the TX Antenna drop-down, select ANT1. This links Port A to the radio slice that transmits on ANT1.
- For PTT source, select LAN. The PGXL then receives its PTT signal from the radio over the network instead of the RCA jack.
- To use Side B, check the Port B box and repeat these settings, selecting ANT2 as the TX Antenna.
Note: The TX Antenna setting is not an internal antenna switch. You cannot transmit on DRIVE A and send the output to OUTPUT B.
Other tab
- Use the slider to set the brightness of the amplifier’s panel lights.
- Fan Mode: choose Standard for quieter operation. Choose Contest if you transmit often and need extra cooling.
- MEffA: leave this off for now.
Important: Click Save. The amplifier stores the changes and reboots.
Set the band data source
- Right-click the wide box to the right of the A channel indicator to open a menu.
- Select FLEX.
- Your radio’s nickname now appears in the box, and the display shows the band and bias mode of the amplifier (AB or AAB).
- If you use Side B, repeat these steps for the Side B box.
Note: If no slice is set to transmit on ANT2, Side B shows no radio name or band data.
Test the amplifier
Before you test, set the radio’s internal ATU to BYP (bypass) and turn ATU MEM off (the MEM button should not be blue). When the amplifier is in Operate mode, you cannot tune an antenna through it. You would only be tuning the amplifier’s input.
- Change bands and modes on the radio. The amplifier should follow. It shows AAB for SSB and AM, and AB for CW, RTTY, digital, and FM.
- Temporarily connect PGXL OUTPUT A to a high-power dummy load.
- In SmartSDR, set your slice to RX ANT1 and TX ANT1.
- Set the TUNE power to 10 W, press TUNE, and watch the power meter on the PGXL. Release TUNE, then repeat at each drive level in the table. Let your dummy load rest before the 40 W and 50 W tests.
| TUNE power (drive) | Expected output into the dummy load |
| 10 W | 225 to 325 W |
| 20 W | 450 to 650 W |
| 40 W | 900 to 1,275 W |
| 50 W | 1,125 to 1,550 W |
Output varies slightly from band to band. These figures assume the PGXL runs on 240 VAC. On 120 VAC, the amplifier has reduced gain (10 to 12 dB instead of a nominal 15 dB) and delivers a maximum of about 600 to 650 W, depending on the band, AC supply voltage, and SWR.
Note: Do not drive the amplifier with more than 70 W at any time.
- Connect a well-matched antenna to OUTPUT A and test on the air. Start at low power so you can see how your home and shack react to high-power RF. If your radio shuts down or equipment behaves unexpectedly, you may have a radiated or common-mode RF problem. Fix it before you resume high-power operation.
Step 5: Connect the TGXL
Place the tuner between the amplifier and your antenna: PGXL OUTPUT A feeds the TGXL, and your antenna moves to the TGXL’s antenna output.
| PGXL OUTPUT A | TGXL TX A input | Always |
| TGXL ANTENNA A output | Your antenna | Always (moves to the Antenna Genius in Step 7) |
| PGXL OUTPUT B | TGXL TX B input | Using Side B |
| TGXL ANTENNA B output | Your second antenna | Using Side B |
- Connect the TGXL to your Ethernet switch.
- Connect the power cable to the TGXL.
- Turn on the TGXL with the small rocker switch next to the power connector.
Step 6: Configure and test the TGXL
Link the tuner to your radio in the TGXL Utility, then confirm it tunes your antenna before you add the Antenna Genius.
- Open the TGXL Utility and select the Local Devices tab.
- Select your tuner and click Connect.
- If the utility offers an Update (a new TGXL release), choose it and let it finish.
- Click the gear icon and select Device Settings, as you did for the PGXL.
Configure each tab
Network tab
- Name: give your tuner a more personal name if you like.
- Select DHCP so the tuner requests an IP address from your router when it boots.
CAT/CI-V tab
FlexRadio tab
- In the Serial Number drop-down, select your radio’s serial number. This links the tuner to the radio for band and frequency information.
- For PTT source, select LAN. The TGXL then receives its PTT signal from the radio over the network instead of the RCA jack.
Note: The TX Antenna setting is not an internal antenna switch. You cannot transmit on TX A and send the output to ANTENNA B.
Genius Integration tab
- Power Genius section: leave this empty when you use a FLEX-6000 or FLEX-8000.
Antenna Genius section: leave this for now. You will link the Antenna Genius in Step 8.
Other tab
- Port A - RX BYP: check this if you want the tuner to bypass antenna A while receiving.
- Port B - RX BYP: check this if you want the tuner to bypass antenna B while receiving.
Port A / Port B - Tune PTT Out: not needed in an all-Flex station.
Band Configurator: set a custom minimum SWR for each antenna on each band, and bypass the tuner on whole bands or on parts of a band. For example, an 80 m dipole may be resonant in the middle of the band but need tuning at the edges.
Note: Enter bypass start and stop frequencies in kHz, not MHz. On 40 m, for example, enter 7110 and 7275, not 7.110 or 7.275.
Important: Click Save. The tuner stores the changes and reboots.
Test the tuner
Test the radio, amplifier, and tuner together on one antenna (or two, if you use Side B).
- Change bands and frequencies. Confirm the radio, amplifier, and tuner all follow.
- Set the radio’s internal ATU to BYP and turn ATU MEM off (the MEM button should not be blue).
- Set the radio’s TUNE power slider to 10 to 30 W. About 25 W is reported to give the best and fastest match.
- Press TUNE on the TGXL, not on the radio. The tuner puts the radio into TUNE mode and tunes the antenna automatically.
- When tuning succeeds, a message briefly appears in green text on the TGXL control panel and on the main window of the TGXL Utility.
Train the tuner
The TGXL stores 20 tuning memories per antenna, per band. Train it on each band:
- Start at the low end of the band and tune the antenna to save a memory.
- Move up about 20 kHz and tune again.
- Repeat until you reach the top of the band.
Because there are only 20 memories per band, space your tuning points further apart on wide bands such as 80 m and 10 m so they cover the whole band.
When the radio, PGXL, and TGXL all work together, move on to the Antenna Genius.
Step 7: Connect the Antenna Genius
Place the Antenna Genius after the tuner and connect your antennas to its numbered ports. The antenna you connected to the TGXL in Step 5 now moves to one of the Antenna Genius ports.
| TGXL ANTENNA A output | Antenna Genius OUT A | Always |
| TGXL ANTENNA B output | Antenna Genius OUT B | Using Side B |
| Your antennas | Antenna Genius antenna ports 1 to 8 | Always |
- Connect the Antenna Genius to your Ethernet switch.
- Connect the DC power connector to the Antenna Genius (13.8 V DC; check polarity).
The Antenna Genius is powered on at the start of Step 8.
Step 8: Configure and test the Antenna Genius
Link the Antenna Genius to your radio and to the TGXL, assign your antennas to bands, then test band and antenna switching on one and two slices.
Power up and choose the port mode
- Power up the Antenna Genius and open the Antenna Genius Utility.
- The first time you open the utility, click the Available Devices link. This opens the Port Chooser, where you choose whether the Antenna Genius serves Port A only, Port B only, or both ports (SO2R). Most setups use SO2R.
- The Antenna Genius Control Panel opens.
Name the device (optional)
- Select the Basic Information tab.
- Type a new name in the Name box if you like, and click Save.
- Click the gear icon again and select Device Settings.
- Select the Bands > FlexRadio tab. FlexRadio Integration - Port A and FlexRadio Integration - Port B boxes appear in the right-hand column.
- In the Port A box, use the Serial Number drop-down to select your radio. With only one FlexRadio on your network, you will see only one serial number.
- Set Antenna to ANT1 and PTT to LAN.
- If you use Port B, repeat steps 3 and 4 in the Port B box, selecting ANT2 as the Antenna.
- Click Save and Reboot. The Antenna Genius stores the changes and reboots.
Note: If the Antenna Genius was previously linked to a different FlexRadio, that radio’s serial number may still be displayed. Verify the serial number to be sure you select the right radio.
Find your Antenna Genius ID
- Click the gear icon and select Device Information.
- Find the Antenna Genius serial number and write down its ID. It is made up of three pairs of characters, for example, C7-F1-DE. Use the ID of your own unit, not the example.
- Click the X to close the window.
Link the Antenna Genius to the TGXL
- Open the TGXL Utility, click the gear icon, and open the Genius Integration tab.
- In the Antenna Genius section, open the Serial Number drop-down and select the ID you wrote down.
- Click Save. The TGXL stores the link and reboots.
Assign your antennas to bands
- Return to the Antenna Genius Utility, click the gear icon, and select Device Settings.
- In the ANTENNAS section, name each antenna you have connected. You don’t need to label unused ports.
- Click the box to the right of an antenna’s name to open its Antenna/Band Configuration.
- Click each band on which this antenna should be used for receive and transmit. Select None to make the antenna available for manual selection on bands it is not assigned to, for example, for receiving between the ham bands. As an example, a log periodic antenna might be assigned to 20 through 6 m.
- Click Accept, then open the next antenna and repeat until every antenna is defined.
- When you have finished, click Accept, then Save. The Antenna Genius stores the changes and reboots.
Special notes for 6 meters
- Always keep power output below 800 W when you use the Antenna Genius on 6 m. The limit matters most in constant-carrier modes such as FT8 and RTTY.
- You get the best SWR and the least loss on Antenna Ports 2 and 7. Use Port 2 when you operate on Side A, and Port 7 when you operate on Side B.
Test the Antenna Genius
One slice
- In SmartSDR, open a slice and select ANT1.
- Step through the bands. On each band, check that the Antenna Genius Control Panel lists only the antennas you enabled for that band (or marked None).
- Where more than one antenna is available on a band, click the A to the left of an antenna’s listing and confirm the antenna changes.
- Repeat for every band.
- Set the slice to RX ANT2 and TX ANT2. Step through the antennas, click the B to the right of each listing, and confirm each antenna changes.
Two slices
- Open a second slice. Set Slice A to ANT1 and Slice B to ANT2, and put the slices on different bands.
- Make Slice A the TX slice and select an available antenna for that band.
- Make Slice B the TX slice and select an available antenna for that band. It must be a different antenna from the one on Slice A.
- Step through the bands on Slice B and watch how the A and B sides of the Antenna Genius Control Panel interact.
- Switch the TX slice back to A and step through the bands again.
Note: You cannot select the same Antenna Genius antenna for both slices when they use different radio antenna settings (ANT1 and ANT2).
Final system test and tips
Run this test with all four devices working together to confirm the whole chain tunes and remembers its settings.
- Select a slice, a band, and an antenna output on the radio, then choose an antenna on the Antenna Genius.
- Press TUNE on the TGXL control panel and confirm the antenna tunes.
- Change to a different band and tune again.
- On the Antenna Genius, choose another available antenna, press TUNE on the TGXL, and confirm it tunes.
- Switch back to the first antenna and confirm the tuner recalls its earlier tuning solution.
- Switch back to the first band and confirm the Antenna Genius selects the right antenna and the TGXL recalls the tuning solution.
Tips
- Rebooting the Antenna Genius: After major configuration changes, you may need to reboot it. Unplug the DC power connector, wait 15 seconds, and plug it back in.
- Antenna memory: You can choose a different antenna for each band from the list you defined. The Antenna Genius remembers the last antenna you used on each band and selects it again when you return to that band, unless the other side of the radio is already using it.
- Tuning memory: When the Antenna Genius and TGXL are configured correctly, the TGXL remembers 20 tuning solutions per band for each antenna.
- Train every antenna: After testing, train the tuner on each antenna on every band where it is available. Start at the bottom of the band and tune, move up about 20 kHz and tune again, and repeat to the top of the band.
Your FlexRadio SDR and Genius products are now configured. If something doesn’t behave as described, open a HelpDesk ticket and tell us which step you were on.
