The Windows operating system has a feature that allows it to shut down PC hardware after some time of perceived inactivity. If your radio is running and Windows shuts down either the Ethernet interface, Firewire interface, or USB interface and enters into a sleep or hibernation mode due to the currently configured Power Option mode, then the real-time constant communication between the radio will stop and the radio will "freeze" requiring you to shut down SmartSDR and possibly may need to power cycle the radio to get it working again.
You can overcome this situation by changing the default Power Plan of Balanced to High Performance and turning off Hibernation
This is a strongly recommended change for any PC running SmartSDR.
Use this procedure to disable Hibernate
1.) Press the Windows + R keys.
2.) Type cmd to bring up the Command window start options. Select the Run as Administrator option.
3.) Type powercfg.exe /hibernate off
(note - this removes hibernate / hybrid sleep options from the Power Plan settings. It also deletes hiberfil.sys.)
(NOTE - This is a global setting that disables hibernation for ALL power plans. It should not be used on a laptop.)
Use the following procedure to change your Power Plan to High Performance.
2.) Type powercfg.cpl to open the Control Panel/Power Options
3.) On the Choose or Customize a Power Plan screen, choose the High Performance power plan. You may need to select the Show Additional Plans drop-down to select the High Performance option.
4.) Click on Change plan settings beside the High Performance plan
5.) Change all options to Off or Never (you can optionally turn off the display)
6.) Click on the Change advanced power settings option
7.) Click on the [+] next to USB settings to expand the options
8.) Click on the [+] next to USB selective suspend setting to expand the option
9.) If the Setting is not set to DISABLE, click on Enable to get the drop-down box and set it to Disabled.
10.) Click on the [+] next to PCI Express to expand the options
11.) Click on the [+] next to Link State Power Management to expand the option
12.) If the Setting is not set to OFF, click on the current setting to get the drop-down box and set it to OFF.
12.) If available, click on the [+] next to Wireless Adapter Settings to expand the options
13.) Click on the [+] next to Power Saving Mode to expand the option.
14.) If the setting is not set to Maximum Performance, click on the current setting to get the drop-down box and set it to Maximum Performance.
15.) Click on the OK button to save the changes.
16.) Click on the Save Changes button.
17.) Close the Power Options screen.
