This is a really good explanation of how to setup the TX audio for PowerSDR, all radios can follow this procedure.. If you can read it directly go to this link.. Thanks Rob, W1AEX
http://www.w1aex.com/psdrgain/psdrgain.html
Setting Transmit Audio Gain Distribution in PowerSDR - W1AEX
I have encountered lots of Flex/SDR users on the air who sound great in every voice mode. However, it’s not uncommon to hear stations who seem to have a lot of grit, distortion, and harshness in their audio in all the voice modes. As it turns out, many of these stations are completely unaware of the multi-function TX meter and how to use it to correctly set the audio gain distribution throughout the Power SDR audio chain. It’s not unusual to find that one of the stages is inadvertently running at maximum gain while another stage is set near the minimum to compensate. This can invoke strange events such as ringing in the audio, distortion, and aggressive ALC action with pumping and audio artifacts. I certainly don’t know everything there is to know about squeezing the most out of the audio functions in Power SDR, but I did find that balancing the gain from start to finish has brought very satisfactory results for me and a number of others who were becoming very frustrated. Pages 77 and 78 of the 2.x.x Power SDR manual "sort of" infer the information given below, but I have found that many users are completely unaware of any audio level settings beyond the front panel Mic slider. Hopefully the steps below will help someone to avoid a disappointing result when they start to transmit!
Note: For those who are using an external audio rack with their Flex Radio I would also suggest reading through the excellent External Audio Setup Tutorial at the blog written by Craig W1MSG. While setting up his external audio chain Craig resolved an annoying issue with his Flex 5000A that involved tearing on audio peaks. It may save you a lot of time!
Steps for achieving balanced audio gain throughout the PowerSDR audio chain:
1. Connect the Flex to a 50 ohm dummy load and select one of the voice modes in Power SDR. Make sure that you have a TX profile selected that has your bandwidth set as you deem appropriate for the phone mode you are using.
2. If you have either the “DX” or “Compander” button selected on the front panel of Power SDR, unselect it now.
3. The “Mic” slider on the Power SDR front panel GUI is scaled from 0 to 70. Place it at the mid-point value of 35.
4. In the upper right corner of the Power SDR interface use the TX dropdown in the meter to select "Mic” as shown in the picture below. This allows you to view the level of the first audio stage of your Flex.
5. From the dropdown menus along the top left edge of the Power SDR interface, select “Mixer” and position it on your desktop so you can access it easily. With the Flex connected to a dummy load, key the transceiver and speak into the microphone at the voice level you typically use on the air. Observe the TX meter Mic level and adjust your level up or down with the “Mic” input level slider (or the slider for whichever input you are using) in the Flex Audio Mixer so that the maximum peaks reach no more than –2 dB. I'd like to mention that this is an absolute maximum level that I never reach while operating. I have found that I get the best results if I set this stage up much more conservatively. In fact, as shown in the meter level displayed in the picture below, my levels at this stage average around -15 dB and rarely ever exceed -10 dB. As someone wisely pointed out to me recently in an email, this not "a cookie cutter" kind of thing and your settings will certainly differ from what someone else finds to be optimal. A little experimentation and adjustment of gain levels at each stage will bring you to a very satisfactory result as long as you don't overdrive one stage and then underdrive another stage to compensate.
6. Now set the TX meter to “EQ”. This allows you to view the level of your second audio stage. From the dropdown menus along the top left of the Power SDR interface, select “Equalizer” and position it on your desktop so that you can access the Transmit Equalizer easily. I would suggest that you enable the 10 band equalizer function at this time, if you have not already done so.
7. Observe the TX meter EQ level as you speak into the microphone and adjust the “Preamp” slider in the EQ interface so that your maximum peaks reach no more than –2 dB. I'd like to mention again that the -2 dB level is an absolute maximum level that you should never exceed. In fact, with my transmit profiles I have found that I get the best results if I set this level so that my average audio rises to around -15 dB with the maximum peaks reaching to around -10 dB as shown in the picture above.
8. Set the TX meter to Leveler. Open up the PSDR tab for DSP and go to the AGC/ALC settings page. As you transmit and speak into the mic, adjust the “Leveler” setting upward or downward from the default setting of 5 but make sure that peaks on the TX meter do not exceed 0 dB. You can further adjust the attack/decay/hang times if the Leveler is not responding quickly enough, or if it seems slow to release. This is largely trial and error, but I found the default decay and hang times to be too long, and reducing them smoothed things so that there was no audible pumping or excessive periods of gain reduction. (Pages 156 - 157 of the PowerSDR 2.x manual provide more details)
9. Set the TX meter to ALC. Open up the PSDR tab for DSP and go to the AGC/ALC settings page. Apply audio and observe that the maximum level of peaks does not exceed 0 dB. If everything in the preceding stages has been set correctly, you should see that your maximum peaks will end up between -5 dB and -1 dB and with your transmit drive set to 100 you should be reaching full RF output in the sideband mode. You can also adjust the attack/decay/hang times of the ALC if you see a peak sneaking through now and then. Again, I found that by reducing the decay and hang times in small steps I could find a setting that resulted in smooth audio without pumping or extended periods of gain reduction. If your ALC levels are exceeding 0 dB on any peaks, reduce the leveler setting or simply reduce your “Mic” level by using the slider on the Power SDR front panel GUI. If you find that your peak RF power output is low with the transmit drive set to 100, go back to the Leveler control and raise the Max Gain setting to increase output. The Leveler has the ability to raise the gain by as much as 20 dB, so there is plenty of audio gain available if you find you need it. Again, when you are done, check the ALC also to assure you are not exceeding 0 dB. There should be a sweet spot where full RF output can be seen without driving the ALC beyond 0 dB. Keep in mind that everyone's setup is a little different. The goal here is to find settings that achieve fairly equal gain distribution throughout the software audio chain. The worst possible scenario occurs when an early stage is overdriven and a following stage is underdriven in an attempt to compensate.
10. When you have finished, your audio should sound smooth and clean. If your transmitted frequency response is not to your liking, the 10 band TX equalizer built into Power SDR works very well and is more than capable of making up for deficiencies in whatever microphone you have selected. Always remember that after you EQ your audio, you should go back through the steps to compensate for any changes in gain.
11. When you get all done with your adjustments, don’t forget to save them in a TX profile! Each TX profile saves its own bandwidth filter settings, front panel Mic setting, DX-Compander setting, EQ preamp level with either the 3 or 10 band adjustments, Leveler setting, AGC/ALC attack and decay, and RF transmit level. If you don’t save your settings, they will be instantly lost when you switch TX profiles! To save a profile, from the dropdown menus along the top left edge of the Power SDR interface, select “Setup”. From the available tabs that are displayed, select "Transmit". On the "Transmit" tab, in the upper left side, find the box named "Profiles". Select the "Save" button and this will bring up a dialog box that will allow you to save your new profile with a unique name. I usually select a name that identifies the mode and bandwidth for which the profile was created, but you can use whatever system works best for you.
Summary: When your levels are set correctly throughout the audio chain, engaging reasonable levels of the Compander or the DX function should result in a very significant loudness difference in your signal, without invoking the ALC or producing any signs of ringing or distortion. It's possible to produce very clean and beautifully balanced audio with the Flex and as long as the gain is set correctly at each stage, it should sound smooth and natural.
Using a cheap electret condenser mic, made from a $2.79 Radio Shack element and a few resistors and capacitors, plugged right into the front panel mic connector of my Flex 5000A, I have received many unsolicited compliments about the audio generated by the Power SDR audio chain. The short MP3 file at the link below of my "naked Flex 5K" was sent to me by Jeff - W2NBC, who was tuning by one winter afternoon as I was running AM on 75 meters. I don't think there's any other multi-mode rig out there that can touch the Flex!
http://www.w1aex.com/psdrgain/flex5kAM.mp3
Additional information: If you are using an external audio chain with your Flex I would suggest that you look at some excellent suggestions from Craig - W1MSG. His tutorial shows settings that he has arrived at to eliminate tearing on audio peaks. The link below will take you to Craig's blog which has a detailed explanation of level settings that have worked well. Thanks for putting this together Craig!
Settings to try when using an external audio rack with your Flex Radio
Written by Rob, W1AEX
