The 60 Meter band, in many jurisdictions, has several special requirements for transmission limits. If you are getting "NO TX" or "Transmit Inhibit" warnings on 60 Meters, you may have something set improperly:
Primary Reasons for TX Inhibit on 60 Meters Operation:
TX Bandwidth is too wide for SSB or Digital Signals.
(100-2900 should be OK. But use NOTHING WIDER than this on 60 Meters)
NOTE: Do not confuse your Receiver Bandwidth Filter setting with your TX Bandwidth, which is set with the "Low-Cut" and "High-Cut" controls
In some locations, 60 Meters is authorized only on certain "Fixed" or "Channelized" frequencies that are limited to a maximum bandwidth of 2800 Hz (2.8 KHz). Primarily, this is the US and the UK.
In normal operations, this means you cannot use a "Low-Cut" no lower than 100 Hz and a "High-Cut" no higher than 2900 Hz.
If your "High-Cut" is set higher than 2900 Hz, then your radio will be "Out Of Band" and will not transmit.
If your "Low-Cut" is set below 100 Hz, then your radio will be "out of band" and will not transmit.
NOTE: In the UK, on the Digital/FT8 Channel, the HIGH-CUT must be 1000 Hz or less.
DO NOT Use "Fake-It" or "Rig" for "SPLITS on 60 Meters:
If your WSJT-X / JTDX or other Digital program is set for "Fake-it" or "Rig," it will shift the dial frequency up or down when you try to transmit, resulting in an "out-of-band" interlock condition, which will trigger an "Out of Band" warning and inhibit transmission.
The Transmit Slice (VFO) is on the wrong "Carrier Frequency."
Check your authorized frequencies and be sure you are on the right "channel" center frequency.
If you are off frequency even by 100 Hz up or down, you may trigger an out-of-band warning and TX Inhibit.
XIT or RIT is turned ON, shifting the TX Frequency when you try to transmit.
Not having the slice TX Button enabled.
Be sure that your intended Slice is enabled as the "Active TX Slice" by tapping the TX Button for the slice. Otherwise, you will get a "NO TX" Warning.
You may have the wrong "Region" set in your radio. The Region setting in your radio may not have the proper frequency allocation permissions for 60 Meter operation where you are.
If your region is not correct, you will need to open a HelpDesk ticket to request a TURF File for the proper region: How to Submit a Request for Technical Support – FlexRadio
Special Information for users in the UK:
Understanding "Out of Band" Problems when Operating on 60m in the UK – FlexRadio
For more information, please refer to this article:
Why Does My Radio Say I Am "Out Of Band" When My Frequency Readout Says I Am Not? – FlexRadio
