Tune TX Suppression
SmartSDR Basic Feature, v4.3.19 · Applies to all models
Tune TX Suppression keeps the TX1, TX2, and TX3 RCA outputs inactive while the radio is in TUNE. You set it per band in TX Band Settings, where it appears as Tune Supp to fit the column width.
This is useful if you key an amplifier from an RCA TX output. With Tune TX Suppression enabled for a band, the amplifier stays out of line while you tune and comes back when TUNE ends.
Enable it on the bands where you run an amplifier, and leave it off everywhere else.
Setting Tune TX Suppression in SmartSDR for Windows
- Navigate to Settings > TX Band Settings, or Settings > Radio Setup > TX > TX Band Settings.
- Find the row for the band you want.
- Select the checkbox in the Tune Supp column, between RCA TX3 and HWALC.
Setting Tune TX Suppression in Maestro and M-Models
- Navigate to Menu > TX Band Settings.
- Scroll the table to the right until the Tune Supp column is visible. The table is wider than the screen, so the column sits off the right edge until you scroll across.
- Find the row for the band you want, then touch the checkbox in the Tune Supp column.
How Tune TX Suppression Behaves
TUNE: With the setting enabled for a band, the TX1, TX2, and TX3 RCA outputs go inactive when the radio enters TUNE on that band. They return to their configured state when TUNE ends.
MOX: The outputs operate normally during MOX. Tune TX Suppression affects TUNE only.
ACC TX: ACC TX is never suppressed. Anything you switch from ACC TX, such as a preamp, keeps working during
TUNE whether or not the setting is enabled.
Default: The setting is off by default on every band, matching earlier releases, so nothing changes until you enable it.
Saving: The setting is saved with the TX profile, alongside the other TX Band Settings columns.
