FlexRadio
- Genius Products The Genius products forum contains articles related to using The 4O3A Genius products with FlexRadio products
- HelpDesk Information This forum contains articles related to the use of the HelpDesk
- FLEX and Aurora Series of Amateur Radio Products This forum is for the Aurora, FLEX-8000, Maestro, and FLEX-6000 series SDRs.
- FLEX Series Amateur Radio Products - Discontiued This forum is for the FLEX-1500, FLEX-3000 and FLEX-5000 series radios
Promoted articles
- Resetting the TGXL (Tuner Genius XL)
- Configuring ICOM exciters with the PGXL, TGXL and Antenna Genius
- Configuring the "Dream Station" - FLEX-8000/6000 with the PGXL/TGXL/AG for Proper Operation
- Required Browsers needed for Accessing the HelpDesk
- How to Access your Support Tickets via the HelpDesk portal
- How to Submit a Request for Technical Support
- SmartSDR v4 – Noise Mitigation Quick Reference
- Aurora - What New Owners Need to Know
- Why SmartSDR+ Does not Have Immediate Access to New Software Features
- Connecting "Balanced" Microphones to Flex 6000 / 8000 / Aurora Radios
- SmartSDR Serial Pass-Through Feature
- How to Connect 3rd Party Microphones with Two-Connector MONO (TS) or Three-Connector "Balanced" TRS Plugs to the Maestro C
- How to Upgrade the Software/Firmware on an M-Model Radio
- How to Configure Fldigi for the FLEX-6000/8000 Radios
- How to Mitigate Common Mode Interference
- How to Set Up SmartLink
- Exporting and Importing your SmartSDR Profiles
- How to Factory Reset your FLEX-6000/FLEX-8000 Radio
- Adjusting your Microphone Settings for Best TX Audio
- What is an EMP and Why Should I Care About It?
- Getting Started with the FLEX-6000
- Configuring the USB Cables Feature for the FLEX-6000/FLEX-8000
- What is Port Forwarding and How do you do it?
- WiFi Requirements and Performance with Maestro
- How to Determine the Correct Amount of RF Preamp Gain for Different Band Conditions
- Rules for EQing Voice for Optimal Phone Operation
- How To Set The Windows Default Playback & Recording Audio Device
- How to Change the Default Audio Sound Device
- SmartSignalâ„¢ (automatic adaptive pre-distortion) FAQ
- Why does the Maestro "C" Require a 24 VDC Supply Voltage?
- Managing Your SmartLink Account and Password
- Why Doesn't the S-Meter Read S0 when the Antenna is Disconnected?
- How Does the Automatic Gain Control (AGC) Function in SmartSDR
- How to Completely Reset am Aurora/ FLEX-8000/6000
- How to Setup SmartLink Video
- ADC Overload with Direct Sampling SDRs - Myths Debunked
- Are there any video cards that do not work well with SmartSDR for Windows?
- Mitigating DPC's and Hard Page Fault issues and their impact on DAX
- How to Manually Reinstall the DAX Drivers
- Why Can't I Transmit on 60 Meters?
- Windows HRESULT Error Codes and Resolutions
- How to Fix the AMBER Light Staying Lit on the FLEX-6000 Series Power Button.
- Why Does My Radio Say I Am "Out Of Band" When My Frequency Readout Says I Am Not?
- How to fix a blank SmartLink login screen when running Win10 or Win8
- Resolving the "single red blink" Fan Error on Start Up
- "Crash on Transmit" Troubleshooting
- How to fix SmartSDR CAT "Trial period has Expired. Program is disabled now" Errors
- How to Determine if Your Network is Configured for Multi-Level NATing and GC-NAT
- How to Manually Uninstall the FlexVSP Driver
- How to Manually Reinstall the SmartSDR FlexControl Driver
- Troubleshooting FlexVSP Not Running Errors
- How to Repair the FlexVSP Virtual Serial Port Driver
- How to do a Complete uninstall of SmartSDR for Windows from your PC
- How to Manually Reinstall the FlexVSP Drivers
- Reasons for Wireless Network Performance Problems
- How to Change the COM Port Assignment for a FlexControl
- What are DPCs and Why Do They Matter?
- Troubleshooting Graphics Issues with SmartSDR-Win
- How to Mitigate FlexControl Latency
- Manually Reinstalling the FLEX-1500 Streaming USB driver
- FLEX-5000 Accessories and Upgrades
- New Power Down Sequence for FLEX-5000C
- Accessing the FlexRadio Knowledge Center
- How to Configure the Operating Parameters in the FLEX Firewire Control Panel
- Troubleshooting Firewire Connectivity Issues
- How to Manually Reinstall a PowerSDR FlexControl
- How to Change the Display DPI settings for PowerSDR
